default image for post
Faking Depth Information with Normal Map
May 3, 2010  |  by Subhamoy Sengupta  |  Beginner, Featured, Materials, Rendering / Lighting, Tutorials, Uncategorized
Here we have an extremely high poly mesh that is, in fact, a bed of small
pebbles. I have sculpted it in Mudbox.
normalMapTip01
If we double click on the mesh in polygon mode (3),
we will see it has 102400 polys.
normalMapTip03
Switch to top view (Numpad 1) and with the cube
primitive tool selected, draw out a poly plane that just covers the bed.
normalMapTip05
Make sure the plane is completely under the high poly bed and there are no
intersecting vertices.
normalMapTip06
Give the low poly plane a material and add an image map to the material
group.
normalMapTip07
Select ‘New Map’ and choose a location, name and
file format. I chose PNG because it is lossless. We do not need alpha channel,
so choose RGB. Doing so will assign a colour to the map, but we need not be
bothered about that. It will be overwritten shortly.
normalMapTip08
Change the effect to Normal.
normalMapTip09
From a side view, measure the height difference between the high poly and the
low poly geometry with the Dimension Tool.
normalMapTip10
Right click on the image name and choose ‘Bake from
Object to Texture’
normalMapTip11
Choose a distance that is safely larger than what we measured.
normalMapTip12
Modo will bake the normal map on that texture.
normalMapTip13
Now, hide the high poly bed and just look at the low poly plane with normal
map in Advanced OpenGL view! The result looks just like the high-poly mesh!
After adding the diffuse texture:
normalMapTip14
This is how it looks without the normal map.
normalMapTip15
And this is how it looks with the normal map.
normalMapTip16
And this is the high poly mesh.
Evidently, though the low poly plane with diffuse texture only is totally
unusable, we can easily get away with the normal mapped version if the object is
not too close and viewing angle is steep.
normalMapTip17
IMPORTANT: Though Modo baked the normals on your
chosen map, the bake information is only stored in primary memory. To store it
actually into the image file, go to FILE > SAVE ALL.
That concludes the tip. I hope it was informative. For questions and/or
comments, please write me to shushens@gmail.com
Support the site – Download includes:
  • High resolution video
  • Modo File
  • Subscribe to our Modo RSS Feed to receive our latest articles and education from Modo Cookie. Become a Citizen
  • Leave a Reply
    Spam Protection by WP-SpamFree
